Conference Bride fails to register after 5.1 upgrade
I just upgraded to CM 5.1 from 4.1.3. After the upgrade, my IOS sccp conference bridges will not register. Looking at the cm interface, it states that the registration is rejected.
From the router I see:
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Thanks in advance...
1 ACCEPTED SOLUTION
Re: Conference Bride fails to register after 5.1 upgrade
I assume you have matched the profile name under the sccp ccm group with that in Call Manger and they match. Try removing the version in the sccp ccm lines. I have found the version is not needed and leave it out so that thing will still work after upgrades. You said you upgraded to Call Manager 5.1, but have version 5.0.1 listed.
Enable the debug sccp all on the GW then make a no sccp/sccp and upload the output if the no sccp/sccp does not fix the problem.
Also upload the show running-config
//Jorge
I have attached the documents requested.
That is what I tried and it worked, too bad I didn't read the post until after! The bad part is a TAC engineer said that it was cosmetic and I didn't need to worry about it...
Silver
Hello Chris,
Were you able to resolve the problem with CFB rejected in CCM? I have the same issue. Could you please let me know what did you do to make it work? I am going to upgard the IOS in the GW from c2800nm-advipservicesk9-mz.124-10.bin to c2800nm-advipservicesk9-mz.124-11.T2.bin.
I was wondering if there's anything that I can do to resolve the issue before upgrading the GW's IOS.
MK
MK
I did a shut/no shut sccp. I did not need to upgrade my IOS at all. Make sure you run the debugs, as they will give you pretty good info.
CHRIS
Silver
The attach is the output of the debus sccp all. Do you see anything?
Silver
Could someone please have a look at the output of Debug sccp all and let me know if there's something wrong?
MK
Nothing glaring in the traces. What version do you have listed in your config (5.01, 4.1), etc.
VIP Super Bronze
This was very helpful. I was doing an upgrade to ccm 6.1.2 and I noticed that I get registration rejected. I previosuly had the following command..
sccp ccm 172.168.107.15 identifier 20 priority 2 ver 5.0.1
Once I removed the Version command, it registered. ( I also did a no sccp and sccp to re-initialize the sccp protocol)
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Under 12.4.22T a version is required. I'm running 6.1(2) and getting Regiration_Rejected messages and CCM_REGISTER_FAILED on show sccp.
Once upgrading to 6.1(2) it seems the gateway requires a IOS upgrade to match.
Voice_Gateway2(config)#no sccp ccm 10.68.68.10 identifier 2 version 5.0.1
Voice_Gateway2(config)#sccp ccm 10.68.68.10 iden
Voice_Gateway2(config)#sccp ccm 10.68.68.10 identifier 2
The CCM version is not specified. Retype and specify the version parameter. If not applicable or if to use the default, explicitly specify version 3.1.
Voice_Gateway2(config)#sccp ccm 10.69.69.11 identifier 1
i just ran into this issue with callmanager 6. the devices were being rejected by callmanager until i added the version 5.0.1 (which is the highest option in 12.4.15T1. Once i added it though, everything worked fine. I have setup many dspfarm configs before and this is the first time i have had any issues.
Here is my final working config.
voice-card 0
no dspfarm
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 10.201.0.51 identifier 1 priority 1 version 5.0.1
sccp ccm 10.201.0.52 identifier 2 priority 2 version 5.0.1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register US-VG-1-CFB
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
hope this helps.
Mike
694
