11-28-2007 09:17 AM - edited 03-15-2019 07:28 AM
Hello Guys,
Could you please verify the attached file and let me know if I have the right Hardware and the right config to make a Hardware conference bridge work?
BT
11-28-2007 09:26 AM
Everything seems to be fine, and you have enough DSP's on your PVDM's, do you see the conference bridge registered on the CCMAdmin webpage? Don't forget to add an enhanced conference bridge using the exact name that you use on the router.
11-28-2007 09:55 AM
When I choose the Enhanced Conference Bridge from the list, it shows the status Rejected. But when I select a Hardware Confernece Bridge it shows registered but it's not working. The name that I am using in the router is CFB folloing the mac address of the router (CFB001AA233CA90). Am I missing something? Do I need to configure the Publisher IP address or Subscriber in the rotuer?
11-28-2007 11:10 AM
PVDM-II should be Enhanced IOS CFB. Are you sure you are being consistent with the underscore in the name (CFB_AMMTL1VCMP01)?? The name has to match exactly.
11-28-2007 12:37 PM
When I select Enhanced IOS CFB, the status in the CCM shows rejected. As soon as I change the enhance IOS CFB to Cisco Conference Bridge Hardware it gets registered but the conf call doesn't work. I am so very confused. Any help?
11-28-2007 12:57 PM
What version of CM?
11-28-2007 01:01 PM
CCM 5.1
11-28-2007 01:05 PM
Your voice gateway needs to be running 12.4 (11) T2 or higher, ran into the same issue you appear to have.
After you upgrade the ios, change
sccp ccm 10.16.8.13 identifier 1 to
sccp ccm 10.16.8.13 identifier 1 version 5.0.1
HTH.
Jared
11-28-2007 01:11 PM
Here's the output of the show version. Do I really need to upgrade to 12.4(13)T2?
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(10), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 16-Aug-06 02:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
gaCAQCMTL1TC1vr01 uptime is 19 weeks, 1 day, 40 minutes
System returned to ROM by reload at 20:32:04 UTC Tue Jul 17 2007
System restarted at 16:26:17 EST Tue Jul 17 2007
System image file is "flash:c2800nm-advipservicesk9-mz.124-10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1101A3VL
2 Gigabit Ethernet interfaces
24 Serial interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
11-29-2007 06:59 PM
Could someone please let me know which bin of 12.4(11)T2 sould I use?
11-30-2007 08:29 AM
Does someone have an answer for me? Please,
11-30-2007 10:10 AM
Since you're running adv. ip services you'd probably want to stick with that.
So download the correct ios for your 2821.
The file should be c2800nm-advipservicesk9-mz.124-11.T2.bin
