VIP Super Bronze
Conference Bridge sessions
Please I want to know how many conference participants can a conference bridge configured with 12 xcoding and conferencing sessions support?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Conference Bridge sessions
They are under service parameters-->CallManager
if you configured 12 conference sessions on your router and changed the above settings then yes
No, you do not need transcoding for conferencing to work, assuming you have the required codecs listed under the conference profile.
Chris
Assuming you are using PVDM2 on your router you can have up to 8 participants per conference session, keep in mind that this setting needs to be adjusted in CallManager as the default "Ad hoc max conference participants" and "MeetMe unicast participants" is set to 4.
HTH,
Chris
VIP Super Bronze
I have been looking at where to set these parameters in callmanager can you please help with the location?
Secondly, If I am using pvdm2 with 12 conference session I can have 96 participants supported.
lastly, Must my xcoding session corespond to my conferencing session?
Chris
VIP Super Bronze
Thanks, you have just helped me clearify loads of stuffs.
176
