Community Member
Conference calls in CME
I have CME 7.1 and I need to implement conference calls up to 8 calls. So I added the following command:
max-conferences 8 gain -6
but I am not able to make conferences for more than 2 parties.
Shall I use conference bridge?
I have also the same problem with Music on hold, I used the command:
moh music-on-hold.au
but it does not work.
So any body can help me??
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Conference calls in CME
Note, moh is sent to external calls only. And, .AU files good for the router are difficult to produce, so just try the default file to begin with.
Please remember to rate useful posts with the scrollbox below.
You need to follow the conferencing chapter in the administration guide, the configuration is explained there.
Community Member
thank you, but what about moh
I already have added the file (music-on-hold.au) to flash and under telephony service I added:
351
