Conference Causes Dropped Calls
I've got a user that when he attempts an ad-hoc conference and attempts the joing the second line the conference, it just disconnects both lines.
What could be causing the conference to disconnect the calls?
  • IP Telephony
1 REPLY
Re: Conference Causes Dropped Calls
Most likely it's a codec issue, check they're all using G711 if using SW CFB or add a XCODER.
If HW CFB make sure relevant codecs are under the dspfarm profile.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
262
