conference issue (4 calls ) on CME 7
Hello everyone,
I have a worry at conference,
I have a 7.0 CME, I can not seem to put a conference with 4 calls, conference calls with 3 it works, but when I add another call he waits, and I can not put in existing conference I followed the documentation for creating conference, but no worries: (
Please can someone help me and explain to me the "Ad-hoc Conference and hardware conference."
here is my config and show:
voice-card 0
dspfarm
dsp services dspfarm
voice logout-profile 1
pin 1234
user 100 password 1111
number 100 type normal
voice logout-profile 2
pin 1234
user 101 password 2222
number 101 type normal
voice user-profile 1
pin 1234
user 200 password 1111
number 200 type normal
voice user-profile 2
pin 1234
user 201 password 2222
number 201 type normal
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
interface GigabitEthernet0/0
description $ES_LAN$
ip address 172.16.3.1 255.255.0.0
ip flow ingress
duplex auto
speed auto
sccp local GigabitEthernet0/0
sccp ccm 172.16.3.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register CME-CONF
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 5500 voip
escription ** cue voicemail pilot number **
destination-pattern 550.
b2bua
session protocol sipv2
session target ipv4:172.16.3.2
dtmf-relay sip-notify
codec g711ulaw
no vad
telephony-service
sdspfarm units 5
sdspfarm tag 1 CME-CONF
max-ephones 58
max-dn 300
ip source-address 172.16.3.1 port 2000
system message CME-7-0
voicemail 5500
max-conferences 22 gain -6
ephone-template  1
ephone-template  20
conference add-mode creator
softkeys hold  Join Newcall Resume Select
softkeys idle  Redial Newcall Pickup ConfList Gpickup Join Login RmLstC
softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback Meetme
softkeys connected  Hold Trnsfer Park Endcall Confrn ConfList Join Select RmLstC
ephone-dn  1  dual-line
number 200
label Poste-200
name Poste-200
corlist outgoing user-international
ephone-dn  2  octo-line
number 201
label Poste-201
name Poste-201
number 200
label Poste-200
name Poste-200
call-forward busy 5500
call-forward noan 5500 timeout 30
corlist incoming user-international
ephone-dn  2  dual-line
number 201
label Poste-201
name Poste-201
ephone-dn  223
number 8000...
mwi off
ephone-dn  224
number 8001...
mwi on
ephone  31
mac-address YYYY.YYYY.YYYY
ephone-template 20
type 7962
keep-conference
logout-profile 1
ephone  32
mac-address XXXX.XXXX.XXXX
ephone-template 20
type 7962
keep-conference
logout-profile 2
CME_CME-7-0#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: 172.16.3.1
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.16.3.1, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 172.16.3.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 32, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
CME_CME-7-0#sh sdspfarm units
conf-1 Device:CME-CONF TCP socket:[20]  REGISTERED in SCCP ver 17/10
actual_stream:32 max_stream 32 IP:172.16.3.1  12243  Conference Dixieland keepalive 134
Supported codec:
                 G711Ulaw
                 G711Alaw
                 G729
                 G729a
                 G729b
                 G729ab
max-mtps:5, max-streams:0, alloc-streams:0, act-streams:0
CME_CME-7-0#show dspfarm profile
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 4
Number of Resource Available : 4
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
2 ACCEPTED SOLUTIONS
Hi Younes,
You have configured conference but it seems you are not using hardware conference and infact software resources is being used which is limited to 3 calls.
Check by using "show sccp connections" for which resource is utilized.
Solution:-
telephony-service
conference hardware
exit
ephone-dn 3 octo
number A123
conference ad-hoc
exit
Nishant Savalia
Regards, Nishant Savalia
Multiple ephone-dn are created with preference so that you have can have multiple conference of 8 parties in each conference.
Actually you can have conference with dual-line also but only 2 parties can have conference i.e. one channel for one participant.
Nishant Savalia
Hi Younes,
Solution:-
telephony-service
conference hardware
exit
ephone-dn 3 octo
number A123
conference ad-hoc
exit
Nishant Savalia
Thank's savalia for your reply,
but when I set the "conference hardware" option at the time the ipphone does not allow the conference
  and just a question, do I need to add another ephone-dn 3 to apply ad-hoc or I apply it on existing ephone-dn (1.2)?
because I already applied ad-hoc but on ephone-dn 1 and 2 but without result.
No, you can not use existing ephone-dn 1 & 2 because they both are dual line and for conference it needs octo line.
And your conference hardware will work only if you have dn configured with octo line as an ad-hoc conference.
Nishant Savalia
So i have to delete all the ephone-dn created, and I have to create with octo-line?
I have noticed when I use the conference ad-hoc command on a ephone-dn octo-line and I connect with the profile, it does not let me make a call, or make a transfer .... as if the phone is locked.
No, you don't have to delete any dn.
Just configure one dn with octo line as conference ad-hoc and that dn you don't have to connect with any profile.
Nishant Savalia
Thank you for your reply, I will test and come again unto you.
So if I understand it, is the configuration in telephony-service and dspfarm and creates a single ephone-dn octo-line for ad-hoc?
Just a question, I saw on another configuration they configure multiple ephone-dn octo-line for ad-hoc conference but with preference, why?
Thank you in advance for your help.
Nishant Savalia
Thank you very much , it's working
278
