You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Conference Issues
I have a Voice gateway CISCO3925, two PVDM3 DSP 64 channels and 192 channels, my issue is that customer can only add 3 persons to a confernce.
 dsp services dspfarm
dspfarm profile 10 transcode
 codec g729br8
 codec g729r8
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 28
 associate application SCCP
dspfarm profile 20 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711ulaw
 codec g711alaw
 maximum sessions 11
Any idea what can the issue be?
Thanks.
  • IP Telephony
You need to mention where
You need to mention where those resources are registered.
java
if this helps, please rate
www.cisco.com/go/pdi
this is registred to a cucm 8
this is registred to a cucm 8.6
Have you adjusted the service
Have you adjusted the service parameters for conference accordingly??
java
Yes i have all configured,
Yes i have all configured, the main issue is that not all phones are afected by this issue. and they are all the same device pool and region.
thanks.
Have you checked your
Have you checked your locations allows the call?? otherwise, you'll need to pull CUCM logs to find the root cause.
java
I would try the "maximum
I would try the "maximum conference-participants" command on the gateway. Details in this thread:
https://supportforums.cisco.com/discussion/10983471/pvdm2-32-maximum-conference-participants
-Jameson
-Jameson
36
