Conference Phone 8831 with 7.1(3)
Is there anyway to add Conference Phone 8831 to CUCM 7.1.3?
in datasheets it is only for CUCM 7.1.5+,
1 ACCEPTED SOLUTION
VIP Gold
No, its not possible. You
No, its not possible. You need to upgrade it to 7.1.5 and then apply device pack top if it.
Suresh
VIP Gold
Suresh
Thank you SureshSo I've to
Thank you Suresh
So I've to download 7.1.5 update image file from Cisco Site , but i found two images
7.1(5b)su6a US Export Restricted - full encryption capabilities (non-bootable) - For upgrade from 7.x. "UCSInstall_UCOS_7.1.5.35901-1.sgn.iso"
7.1(5b)su6a US Export Unrestricted - fewer encryption capabilities (non-bootable) - For upgrade from 7.x. "UCSInstall_UCOS_UNRST_7.1.5.35901-1.sgn.iso"
which one should I select
and is the upgrade will be easy task like installing device package withount need to re-configure anything
VIP Gold
It depends on what CUCM you
It depends on what CUCM you running whether it is restricted or unrestricted, you can find it with the help of below link. If CUCM is installed as restricted then you must go for restricted version (UCSInstall_UCOS_7.1.5.35901-1.sgn.iso) only.
https://supportforums.cisco.com/discussion/12079741/how-find-installed-cucm-iso-restricted-or-unrestricted
If you plan well, then it is not a difficult activity its like device pack installation just you need to switch the version after new iso installation and you dont need to reconfigure anything except frimware; if you dont want to update the firmwares then you can revert back the firmware names in device default.
Suresh
Thank you, I  really
Thank you, I  really apreciate your answers
VIP Gold
You r most welcome :-) I am
You r most welcome :-) I am glad that I answered your queries.
Suresh
229
