Conference problem on CUCM 8.6
Hi voice team,
I'm in trouble when I try to make a conference with an external number. The conference with internal extensions work perfectly, but when I try to add a third number and it is out of business, when I click on the softkey Confrn to unite the three links, the external connection goes down, what to do in this case?
Thanks.
Thiago
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Super Bronze
You do not have a hardware conference brisge configured.. You need to do this..
sccp ccm group 30
description Transcoder
bind interface FastEthernet0/0
associate ccm 3 priority 3
associate profile 3 register MTP002255D8A1A8
associate profile 1 register Hardware_CFB
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 4
associate application SCCP
Then in cucm configure IOS enhance conference bridge and use the name Hardware_CFB,
You then need to assign this to a MRG and the MRG to a MRGL. Then assign the MRGL to the phones and gateway. You can just use your existing MRG
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
Are you using software or hardware conference bridge?
What codec is the remote party using? When you call it what codec is selected?
Can you join 3 internal parties?
Chris
I use software conference bridge, how do I check what codec that uses the remote party? Yes I can add 3 internal parties.
Thanks.
This seems to be codec issue, software bridge only supports G711 and sounds like your PSTN call may be G729. To check it call the remote party from the phone, once connected double click the "?" button on 79XX phone and it will display the codec used.  If it is anything other than G711 you will need to either use hardware bridge or transcoders.
HTH,
Chris
We're using G.729 when making external connection, how to proceed in this case?
thanks
Do you have a voice gateway with spare DSPs (PVDMs) available?
If so create conference dsp profile there, register to CUCM and assign to MRG used by the phones.
HTH, please rate all useful posts!
Chris
the command that checks if there is spare dsp? and how can I create a profile conference on the router?
I have it configured on the router:
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
that´s right?
Post "sh run" and "sh inv" to help us determine if you have any available DSPs. As to the configuration it would be something like this:
voice-card 0
dsp services dspfarm
sccp local
sccp ccm identifier 3 version 7.0
sccp ccm identifier 2 version 7.0
sccp ccm identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface
associate ccm 1 priority 1
associate ccm 2 priority 2
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 8 <-- if you enter ? it will tell you want you have available
no shut
HTH,
Chris
Hi, follows the configuration:
voice-card 0
application
service onramp-app flash:/app_faxmail_onramp.2.0.1.3.tcl
service offramp-app flash:/app_faxmail_offramp.2.0.1.1.tcl
username cisco password 7 143443180F56
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  double-answer
--More--                             category 2
  answer-signal group-b 1
description LINK BRASILTELECOM 1
controller E1 0/0/1
framing NO-CRC4
cas-custom 0
  country brazil
  metering
  double-answer
  category 2
description LINK BRASILTELECOM 2
ip address 172.26.149.132 255.255.255.0
duplex auto
speed auto
--More--                           !
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.26.149.144
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:0
--More--                           voice-port 0/1/0
cptone BR
connection plar 8000
station-id name Ligacao Celular
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/0/1:0
voice-port 0/2/0
cptone BR
voice-port 0/2/1
cptone BR
voice-port 0/2/2
cptone BR
--More--                           voice-port 0/2/3
cptone BR
voice-port 0/3/0
cptone BR
voice-port 0/3/1
cptone BR
voice-port 0/3/2
voice-port 0/3/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.26.149.133
ccm-manager config
mgcp
mgcp call-agent cur1sr05 2427 service-type mgcp version 0.1
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
--More--                           mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 172.26.149.133 identifier 3 version 7.0
sccp
sccp ccm group 30
codec g711ulaw
codec g711alaw
--More--                            codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dial-peer voice 100 pots
description REDE PUBLICA
translation-profile incoming ENTRADA
translation-profile outgoing INTELIG
destination-pattern 0T
fax rate disable
direct-inward-dial
port 0/0/0:0
forward-digits all
no register e164
dial-peer voice 101 pots
--More--                            fax rate disable
direct-inward-dial
port 0/0/1:0
forward-digits all
no register e164
dial-peer voice 1 voip
preference 2
destination-pattern 8...$
session target ipv4:172.26.149.133
dtmf-relay h245-signal
dial-peer voice 1001 pots
description 8080-FAX GERAL
destination-pattern 8080
fax rate disable
port 0/2/0
dial-peer voice 1002 pots
description 8081-FAX COMERCIAL
destination-pattern 8081
fax rate disable
port 0/2/1
--More--                           !
dial-peer voice 1005 pots
description 8085-AUDIO CONF
destination-pattern 8085
fax rate disable
port 0/3/0
dial-peer voice 1006 pots
description 8072-MODEM
destination-pattern 8072
fax rate disable
port 0/3/1
dial-peer voice 102 pots
description CELULAR LOCAL
destination-pattern 0[7-9].......$
direct-inward-dial
port 0/1/0
forward-digits 8
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
--More--                           !
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 1004 pots
port 0/2/3
--More--                           !
gateway
timer receive-rtp 1200
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
line aux 0
line vty 0 4
password 7 044805140C285F4D065C5447
login local
scheduler allocate 20000 1000
ntp logging
ntp update-calendar
ntp server 10.0.0.253
end
--More--
RT-TELEFONIA#    sh inve
RT-TELEFONIA#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FTX1232A2QX
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC12305S9Z
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: FOC122802LX
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC12151YM9
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC12280Z6W
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC12301ZBQ
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC12295SC6
If all of your calls are using G729 you may run low on PVDMs as you have a total of 128 channels, and 2 E1s (60 ports) and 12 analog ports, if all ports are busy with G729 codec you will need (60+12)*2=144 channels.
Is there a reason you are sending these calls out as G729 instead of G711?
You also have a transcoder already defined, check to see if it is registered in CUCM and assigned to proper MRG and then see if you can add more sessions to it:
maximum sessions 4  <-- this number
Chris
but works with CUCM 5.1, after migration to CUCM 8.6 that stopped working. All calls use G.729, but increasing the "maximum sessions" already solve my problem?
VIP Super Bronze
sccp ccm group 30
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 4
On CUCM -> Conference Bridge -> CISCO IOS enhance conference bridge->
Do not do encrypted unless you have encryption enabled on your CUCM.
HTH,
Chris
Hi, this setup worked with the conference, thanks to everyone who helped me.
Best regards,
Great it worked for you.
Please rate all useful posts!
Chris
VIP Super Bronze
Thiago You didnt rate any of Chris Posts! I have rated one for you. +5 Chris for the excellent support
4083
