09-25-2014 02:50 AM - edited 03-17-2019 12:17 AM
I have a requirements for a Call Conference Solution to connect branches around 45 Branches,suggest which conference design suits for this requirements in the scenario of CME/CUCM?
09-25-2014 04:12 AM
The easiest and cheapest solution is to use the CUCM integrated conference based solution. This will require you to purchase or add additional PVDM on your voice gateways. You can either do this/branch or use a group of dedicated branch gateways for this.
09-27-2014 02:14 AM
Ayodeji,
What else i need to upgrade?
09-27-2014 03:16 AM
Hi Siva,
You can refer to DSP calculator for PVDM details.
http://www.youtube.com/watch?v=lWgZrSd05Ks
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
regds,
aman
09-27-2014 06:31 AM
Aman,
I suspect in CUCM we can have maximum upto 8 sessions,only 8 conference party can participate..so shoud i need to go for webex session?
09-27-2014 06:52 AM
That is inaccurate, with software based conferencing provided by CUCM you can have up to 128 G711 participants, with DSP based conferencing you can have up to 64 participants if I recall (when using G711) and 32 when using G729, or 32 and 16, I forget :-) Number of sessions would depends on amount of DSPs you have for which you can use the provided link to DSP calculator.
Chris
09-27-2014 09:59 PM
Chris,
In case of Meet me conference how many participants can able to join in the session?
09-28-2014 08:27 AM
Same as AD-hoc conferencing, limited by bridge capacity, you just need to remember to adjust max meet me participants service parameter which defaults to 6 in CUCM.
10-08-2014 06:00 AM
I would recommend to go for Meetingplace express supports your requirement
10-08-2014 06:13 AM
Meetingplace express has been dead for several years (version 2.1 was last and we are on 10.5 across the board), in fact MeetingPlace as a product is dead as well replaced by CWMS.
Chris
09-25-2014 05:59 AM
In addition to Deji's response (+5), you need to provide more details, i.e. do you require scheduling ability, recording, how many participants in each conference and total number of conferencing sessions, this will let us know if you would be OK with CUCM based conferencing or require external bridge such as WebEx.
Chris
09-27-2014 02:12 AM
Chris,
Thanks for the information,
In case of CUCM/CME should i need to upgrade the pvdm in HQ,what else i need to considerd?
