Community Member
Conference using phone Built in Bridge dropping calls
I have a client that is having an issue using the confrn softkey.  Here are the steps that are happening.
User is on a call
User presses confrn button
User diales number
New participant answers the phone
User presses confrn button again
Call gets dropped.
Not sure why this is happening as I have not seen this before.  All participents are using g711.  and the Built in Bridge option is enabled on the phone.
BIB is not used for
BIB is not used for conferences, only for barge. Do you have a CFB???
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Really did BIB used to be
Really did BIB used to be used for that cause I thought it was.
Yes they do have a software CFB setup and it is still having this issue.  They have also discovered that if the press the conf button the second time while the phone is still ringing then it works.
You probably need to pull
You probably need to pull CallManager traces to find the reason the call is being dropped.  Most likely some sort of codec/region issue.
403
