Conferencing issue
Greetings,
I have a strange issue with conferencing.
I have a 3825 router configured with 2 PVDMII-64 chips. All conferencing resources are registered correctly to the Call Manager. The MRG contains the conference resources for the call manager and the 3825 router. When I try to do an ad-hoc conference (All parties are in the same region), I get a reorder tone.
I then moved the CFB0013c37c02f0 (the router conferencing bridge) out of the MRG, tried the call again and it worked?
My question is - Is my configuration of the SCCP resources on the router configured incorrectly?
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CFB0013c37c02f0
associate profile 2 register XCD0013c37c02f0
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 12
1 REPLY
Re: Conferencing issue
at least that part of the config seems to be fine, you lack some of the whole config for this in the post.
do a
no sccp
sccp
at the router, verify the status of the CFB as registered in CCM. reset the CFB in CCM and try again
you can issue a show dspfarm all to verify the status at the router
java
if this helps, please rate
www.cisco.com/go/pdi
96
