Config Dump from Call Manager 4.1
We need to migrate from a CUCM 4.1 to a UC560.
If memory servers, CUCM is the older Windows based version of CUCM.
Are there any tools or methods I can use to pull a readable config dump from a CUCM 4.1 to serve as basis for the config of the UC500?
I'm interested in all the system config such as CAC & trunk config, and all the existing user info such as phone features & MAC addresses.
Chris
1 ACCEPTED SOLUTION
Re: Config Dump from Call Manager 4.1
All you can use is BAT to get the phone info, systems are completely different and you'll need to build the config from scratch.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
java
98
