Config example H323 to SRST mode
Can somebody give me the config example of H323 gateway for SRST?
Re: Config example H323 to SRST mode
H323 gateway is connected in real work to CUCM
Hi Alexandr,
SRST Administration Guide will help you with your SRST configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srstsa.html
Besides the SRST configuration in your router, you have to create an SRST Reference in your CUCM and assign it to the device pool of your remote IP Phones.
Hope it helps you.
Best regards,
- Adrián.
Bronze
What do you want the SRST to do and I can send you a sample that will asisst with the doc and tip Adrian has outlined
Paul
THe requirements for SRST are simple. SRST should work in autonomous world without CUCM in H323 mode.
Thank you!
1629
