Community Member
Config History
On CUCM 7.0 I would like to find out what and when config changes were made.
We had an issue which caused a system outage and it turns out to have been a simple config error. I would like to be able to see when that was changed.
I have looked on the server OS cli for any commands but nothing is obvious.
is there a way to do this?
1 ACCEPTED SOLUTION
Re: Config History
You can use the cisco role based security traces for this, there are a lot of posts on the subject if you search NetPro
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
Re: Config History
java
java
135
