config problem with ex60 on CUCM8.6.1
Hi all,
I'm currently stuck on setup the EX60 on CUCM8.6, here are some info ...
CUCM 8.6.1
Tandberg ex60 TC4.2
In CM8.6, (10.10.10.10) I'm able to add new device for telepresence ex60, and I have enabled the digest user authentication in ex60 SIP security profile.
In ex60, I config the Network SIP
DN: 7722
URI: 7722@10.10.10.10
Login: sam
Password: password
Proxy: 10.10.10.10
Do I miss anything, or config incorrectly?
Sam
TC5 required for registering with CUCM 8.6 and above.Please refer the below release notes.
http://www.cisco.com/en/US/docs/telepresence/endpoint/software/tc5/release_notes/tc_software_release_notes_tc5.pdf
Gnaneswaran.
-pls rate helpful posts...
I tried to upgrade the Ex60 to TC5
But after ex60 finished upgrade and restart, it prompts "missing release key", then I tried to look into the web gui interface, and found that my release key can only be used with TC 4.....
Sam
580
