Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
config QoS for cisco IP phone with 3750X, 2960
I was asked to set QoS for LAN for cisco IP Phone. I have checked several reference but is not clear for me which commands must I used in order to
warranty QoS.
Mainly I know I must set
mls qos  (global configuration)
for switch's ports
Switch(config-if)#mls qos trust device cisco-phone
Switch(config-if)#mls qos trust cos
which other commands must I used in order to set QoS correctly?
For upllinks between switch core an access switch, is required some special config?
regards
1 REPLY
Blue
He
Please see below QOS SRND. It has configuration examples for most of the switches.
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Ronak
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
636
