Community Member
config RAID on MCS 7825 i5
Hello
I add a new HDD to my server ( MCS 7825 i5) that already bought with one HDD. now the server has 2 HDD.
My Problem is when I try to configure RAID 1 on my server it seem like the the controller not install.
so I need to make sure if the controller is installed otherwise Is there are any procedure to configure RAID on my server.
thank you for your relpys
Best Regards
Are you able to access the
Are you able to access the LSI configuration? Please reference the guide below:
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/ibm_doc_sraidbr_10i-0508_install-users-guide.pdf
Yosh
HTH Regards, Yosh
Community Member
thank you for your reply it
thank you for your reply it seem that not existe in the server I see with system ingeniere and he confirmed me that the card not existe in the server
thank you again for your reply
Gotcha!Yosh
Gotcha!
Yosh
HTH Regards, Yosh
68
