Community Member
Configurate TFTP for Phone
Hi All,
There are phones using static IP registered on CUCM 3, now I would like to register those phones on another CUCM. Since I could not amend the TFTP setting as simple as changing the option 150 of DHCP, is there any way that I could change the TFTP setting of the phone without touching the phone physically when the phone is using static IP???
William
1 REPLY
Hall of Fame Super Gold
There is software that allows to remotely control the phone presentig a clickable image of it.
You can search for more information about these.
112
