Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Configuration Analog Line on router 2800
Hi I have an analog line with the number 9192595 and it'd connected to analogic device, Now I will need to conect this line to router 2800 in a FXO port, This router works for IP Telefhony, the idea is that someone dial this number it will forward to IP Phone with the DN number 23500. My question is, how can i do that ??
thks
Manuel
Re: Configuration Analog Line on router 2800
configure a PLAR
voice-port 0/1/0
connection plar XXXX
Make sure to have dial-peers for destination
If it's controlled by MGCP configure the attendant DN in CCM.
java
if this helps, please rate
java
www.cisco.com/go/pdi
hey Javalenc
let me c if I understand this very well , if I have a pots line coming with rj 11 , I can have a 2800 router do the voip for the internal calls and can I receive a calls as well,
159
