Configuration E1 R2 Trunks
Guys,
need help to configure our gateway 2811. I have two (2) E1 ports.
Port: 0/0/0 - to be used for DID
Port: 0/0/1 - to be used for DOD
Can you guide me to configure first my controller then a sample dial-peer I will use to use for incoming and outgoing.
I want to use port: 0/0/0 for DID and port: 0/0/1 for outgoing.
I need your advice and quick action to this issue.
regards.
1 REPLY
Re: Configuration E1 R2 Trunks
hi, please find below configure is workable in our Manila Branch. I hope this can help you.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
sip
voice class codec 99
codec preference 1 g711ulaw
codec preference 2 g729br8
voice translation-rule 1
rule 1 // /5/
!voice translation-profile inbound
translate called 1
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
cas-custom 0
country philippines
dnis-digits min 1 max 3
description TYPE=PRI DEST=xxx BW=2M!
voice-port 0/0/0:0
translation-profile incoming inbound
dial-peer voice 402 voip
description xxx
preference 1
destination-pattern 5...
voice-class codec 99
voice-class h323 1
session target ipv4:
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
139
