Configuration file in CME
Hi there,   when we enable CME in cisco router,  after issue Telephony-service --> create CN, system will display following:
                          CNF file createion is aleady on,   Updateing CNF files,   CNF files update complete.
can someone explain:    what is in side of this file?
                                   where is it located?
                                   can we actually open have a look?
                                   does it records all ephone ephone-dn information?   there are mutiple CNF file or just a single file.
I guest it is a single file with the info for all the ephone, so when each phone contact the tftp server,  it will get it's configure info from that CNF file?  am I correct here?           Cheers Roy
Silver
CNF files are specific phone
CNF files are specific phone configuration files.
You can choose where they are located - under "telephony-service" you have "cnf-file location ..." or something similar.
When you find exact location using "show flash..." you can look inside that file using "more flash:<file name>".
HTH,
Dragan
HTH, Dragan
Hi  Draganthanks for the
Hi  Dragan
thanks for the reply, you are right I can specify the locaiont of the files. My intial questions is wonderging where is the default locaiotn for the CNF-File.  the link bellow explained that it is in the sysmtem, so that is why when I try to see it via show flash:,will not see it. but you can change it location as you explained,   after I change the location to Flash, and create cnf file again, it takes while then all the cnf files can be viewed inside of flash.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmefiles.html
28
