Configuration for H323 Voice Gateway with 5 FXO Ports
I have a working configuration for 1x FXO ports and now I need to add 4x FXO ports to the gateway. I need to know the easiest way to configure it. I know I can create a truck group and add all FXO ports into it and add it to each dial-peer. My question is what about the voice translation-rule, voice translation-profile, and dial-peer? Please see below for my 5x phone lines and my configuration for 1x FXO port.
Phone (234)567-8900 to ext500 port 0/0/0
Phone (234)678-9000 to ext501 port 0/0/1
Phone (234)456-7890 to ext502 port 0/0/2
Phone (234)321-4789 to ext503 port 0/0/3
Phone (234)234-5678 to ext504 port 0/0/4
voice translation-rule 1
rule 1 /2345678900/ /500/
voice translation-rule 2
rule 2 /500/ /2345678900/
voice translation-profile INCOMING_8900
translate called 1
voice translation-profile OUTOGING_8900
translate calling 2
voice-port 0/0/0
translation-profile incoming INCOMING_8900
translation-profile outgoing OUTGOING_8900
description line 2345678900
caller-id enable
connection plar opx 500
trunk-group FXO1
dial-peer voice 11 voip
description *** CUCM Peer ***
destination-pattern 500$
Voice-class codec 1
Voice-class h323 1
Session target ipv4: 10.0.0.2
dtmf-relay h245-signal h245-alphanumeric
ip qos dscp cs3 signaling
no vad
  • Should I create 2 voice translation rules for each line? So total of 10 voice translation rules?
  • Should I create 2 voice translation-profile for each line? So total of 10 translation-profiles?
  • Should I create new dial-peer voice voip for each ext such as destination-pattern 500$, destination-pattern 501$ and so on…?
Thank you all in advance!
Hello1- For Incoming calls ,
Hello
1- For Incoming calls , just do "connection plar opx 5XX" under voice-port. So you can easily manage your incoming calls by using this command to match incoming calls , wihout using translation-rule for incoming.
2-For Outgoing calls , No need for outgoing translation rules. You can do the below to match using ANI to forward the call to correct FXO port based on your design.
dial-peer voice 500 pots
destination-patter 9[2-9]......
forward-digits 7
answer-address 500         /See the call with 500 will go using 0/0/0 , you need to do for others exts.
port 0/0/0
dial-peer voice 501 pots
forward-digits 7
answer-address 501         /See the call with 501 will go using 0/0/1 , you need to do for others exts.
port 0/0/1
3-For sure no need o create for each ext specific dial-peer , you can only use the below
destination-patter 5..     /5.. will match all incoming exts/
please rate all useful information
Islam,Thank you very much.
Islam,
Thank you very much. Let me confirm with you again.
1. I don't need to use any voice translation-rule or voice translation-profile if I do the following on very voice port right? Such as:
voice-port 0/0/0
caller-id enable
trunk-group FXO1
voice-port 0/0/1
description line 2346789000
caller-id enable
trunk-group FXO1
voice-port 0/0/2
description line 2344567890
caller-id enable
trunk-group FXO1
and so on.....
2. You mean I need to do this for all outgoing calls dial-peer? I thought I can just add everything to a trunk-group FXO1 and put trunk-group FXO1 on every dial-peer voice pots such as:
# dial-peer voice 10 pots
# description *** For 7 digit local calls ***
# destination-pattern [2-9]……
# tone ringback alert-no-PI
# forward-digits 7
# trunk-group FXO1
# dial-peer voice 11 pots
# description *** For 911 Calls ***
# destination-pattern 911
# forward-digits 3
# trunk-group FXO1
3. Got it. I just need one voip dial-peer right? Can you double check the following?
destination-pattern 5..
Voice-class codec 1
Voice-class h323 1
no vad
HelloPoint 1, and Point 3 are
Hello
Point 1, and Point 3 are perfect , for Point 2 , kindly find the below:-
answer-address 501                 //you have to add the number "ANI" which you need to go out from FXO 0/0/0 or FXO1//
# forward-digits 7
# trunk-group FXO1
# forward-digits 3
# trunk-group FXO1
Please rate all useful information
Thanks again Islam.So you
Thanks again Islam.
So you mean I will need to put "answer-address ANI" on every single dial-peers with all 5 extensions? such as the following?
For Ext 500
# dial-peer voice 9 pots
# description *** For outgoing 9 Traffic to PSTN ***
# destination-pattern 1……….
# forward-digits 10
# answer-address 500
# trunk-group FXO1
# forward-digits 7
# trunk-group FXO1
# forward-digits 3
# trunk-group FXO1
# dial-peer voice 12 pots
# description *** For 011 International Calls ***
# destination-pattern 011T
# no digit-strip
# trunk-group FXO1
For Ext 501
# dial-peer voice 13 pots
# forward-digits 10
# answer-address 501
# trunk-group FXO1
# dial-peer voice 14 pots
# forward-digits 7
# trunk-group FXO1
# dial-peer voice 15 pots
# forward-digits 3
# trunk-group FXO1
# dial-peer voice 16 pots
# no digit-strip
# trunk-group FXO1
For Ext 502
# dial-peer voice 17 pots
# forward-digits 10
# answer-address 502
# trunk-group FXO1
# dial-peer voice 18 pots
# forward-digits 7
# trunk-group FXO1
# dial-peer voice 19 pots
# forward-digits 3
# trunk-group FXO1
# dial-peer voice 20 pots
# no digit-strip
# trunk-group FXO1
and so on for other additional ext 503, 504
Hello  Your configuration
Hello
Your configuration above meet the below:-
1-Outgoing calls will hit FXO1 trunk " so call will hit fxo 0/0/0 , if busy will hit 0/0/1 ,then 0/0/2" , so on the above configuration you will be unable to force your outgoing call from 500 to hit fxo 0/0/0 , may be sometime wil hit fxo 0/0/1 or fxo 0/0/2.
HelloThis configuration if
Hello
This configuration if you need to do mapping to make a specific number hit specific port . Mapping to FXO , so ou can use the below:-
voice-port 0/0/0
caller-id enable
trunk-group FXO1
voice-port 0/0/1
caller-id enable
connection plar opx 501
trunk-group FXO2
voice-port 0/0/2
caller-id enable
connection plar opx 502
trunk-group FXO3
voice-port 0/0/3
description line 2343214789
caller-id enable
connection plar opx 503
trunk-group FXO4
voice-port 0/0/4
description line 2342345678
caller-id enable
connection plar opx 504
trunk-group FXO3
For Ext 500
# forward-digits 10
# trunk-group FXO1                                   /500 will use fxo 0/0/0 for outgoing calls/
# forward-digits 7
# trunk-group FXO1
# forward-digits 3
# trunk-group FXO1
# no digit-strip
# trunk-group FXO1
For Ext 501
# forward-digits 10
# trunk-group FXO2                         /501 will use fxo 0/0/1 for outgoing calls/
# forward-digits 7
# trunk-group FXO2
# forward-digits 3
# trunk-group FXO2
# no digit-strip
# trunk-group FXO2
For Ext 502
# forward-digits 10
# trunk-group FXO3                                      /502 will use fxo 0/0/2 for outgoing calls/
# forward-digits 7
# trunk-group FXO3
# forward-digits 3
# trunk-group FXO3
# no digit-strip
# trunk-group FXO3
Islam,I got it for the
Islam,
I got it for the outgoing calling. What about for incoming calling? Do I need to do something like below for different trunk-group as well too?
# dial-peer voice 1 pots
# description *** For Incoming Call Matching ***
# incoming called-number .
# direct-inward-dial
# trunk-group FXO1
# dial-peer voice 2 pots
# trunk-group FXO2
# trunk-group FXO3
and so on?
Hellono , use connection-plar
Hello
no , use connection-plar opx under voice-ports .Lets try to summarize the above to start test
Incoming calls
voice-port 0/0/0
caller-id enable
trunk-group FXO1
voice-port 0/0/1
caller-id enable
trunk-group FXO2
voice-port 0/0/2
caller-id enable
trunk-group FXO3
2-Outgoing calls
A- option to allow all users hit FXO ports randomly using one trunk which includes all FXO ports.
# forward-digits 7
# trunk-group FXO1
# forward-digits 3
# trunk-group FXO1
B-mapping FXO to interna ext , to allow 500 go to fxo1 , 501 go to fxo2 , 502 go to fxo3. Example for 501 which will hit fxo2
For Ext 501
# forward-digits 10
# forward-digits 7
# trunk-group FXO2
# forward-digits 3
# trunk-group FXO2
# no digit-strip
# trunk-group FXO2
Islam,Got it! You mean I don
Islam,
Got it! You mean I don't need the dial-Peer voice 1 pots at all with direct-inward-dial right? can you please double check the following configuration? This is for direct mapping for both incoming and outgoing calls.
Thanks!
voice-port 0/0/0
caller-id enable
trunk-group FXO1
voice-port 0/0/1
caller-id enable
trunk-group FXO2
voice-port 0/0/2
caller-id enable
trunk-group FXO3
Ext x500
# forward-digits 10
# trunkgroup FXO1
# forward-digits 7
# trunkgroup FXO1
# forward-digits 3
# trunkgroup FXO1
# no digit-strip
# trunkgroup FXO1
Ext x501
# forward-digits 10
# trunkgroup FXO2
# forward-digits 7
# trunkgroup FXO2
# forward-digits 3
# trunkgroup FXO2
# no digit-strip
# trunkgroup FXO2
Ext x502
# forward-digits 10
# trunkgroup FXO3
# forward-digits 7
# trunkgroup FXO3
# forward-digits 3
# trunkgroup FXO3
# no digit-strip
# trunkgroup FXO3
dial-peer voice 1000 voip
Voice-class codec 1
Voice-class h323 1
no vad
Hi+5 for you . Everything is
+5 for you . Everything is ok now . You can go to test.Do not forget for rate and correct answers.
Islam,Thanks again! Yes, that
Islam,
Thanks again! Yes, that's work! One more question. How about if I want to add phone x533 which share both external incoming and outgoing call with x502? What will be the configuration looks like for that?
My main goal is phone x533 can make external calls to outside and share the same number as (234)456-7890. That is possible right?
299
