Configuration help with France Telecom T2 connection
Hello
I have a "T2" connection from France Telecom.  An ISDN30 (E1) was requested.  Handoff is RJ45.  A standard E1 config is not working.  Does anyone have experience with T2 connections?  As best I can tell, a T2 is essentially the same as an E1.  Router is a 3845, connection can be H323 or MGCP back to a Call Manager.  I could use help on the controller and serial configuration.
Right now I have:
controller E1 0/1/0
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
Thanks very much for any assistance.
Super Bronze
Re: Configuration help with France Telecom T2 connection
Well, not sure what T2 is (the liquid Terminator wasn't it?)..
But most places in Europe outside the UK use 'framing no-crc' under your E1 controller config.
Try that...
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hall of Fame Super Gold
Always begin with "show controllers E1".
We have the same problem.... Can you tell me how you go this thing to work. I have the exact same E1 Config on my router.
Abraham
Hi Abraham
I believe the root cause of my issue was physical.  The connection from the Fance Telecom box to the router required a cross over instead of a standard T1 cable or a straight through.  If you are still having issues - let me know and perhaps paste in your config.
-Doug
Thank you so much for the reply Doug.
I have copied the relevant parts of the Running Config and is given below.
Could you please review this.
network-clock-participate wic 0
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
controller E1 0/0/0
controller E1 0/0/1
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no cdp enable
Thanks in advance
Abraham
Hi Abraham
Here are the relevant pieces of my configuration, this is on a 2811.  I am using H323 back to a CM 7.  You will see mine is a fractional E1 so the timeslots are different.
card type e1 0 2
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
voice-card 0
dspfarm
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-16
interface Serial0/2/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/2/0:15
cptone FR
2949
