Configuration Help
Hi all,
One of our customer requested for an upgradation, from Exsting 30 channels to 150 channels.Current configuration is attached.Kindly help to configure the same.
Customer requirement.
[1], Additionl PVDM modules on the routers to support more VOIP channel.
[2], Additional 4 E1 ports for voice trunks between router and customer PBX.
[3], Soft upgrade the Internet Access link(LL=10M, port=2M) to Internet Access link(LL=10M, port=2M).
[4], Need to add  120 channel on  IP Trunking gateway.
Current configuration and Diagram attached.
Thanks in advance.
Lijesh
Hall of Fame Super Gold
Re: Configuration Help (Urgent)
And your question is ?
Please do not solicit for urgent help on a freely contributed user forum.
If you need pre-sale and configuration support, engage a reputable consultant or certified cisco partner.
Hi  bevilacqua,
I understand the importance of the forum, that was a immediate requirement and i don’t have much knowledge about Voice related things.
Would be helpful if you can give some inputs on this.
Thanks in advance.
Lijesh
Since you have no experience, I recommend you engage a reputable professional or certified partner.
Otherwise, it will be impossible for you to satisfy your customer requests.
197
