Community Member
Configurator Tool I am not able to find CUCM 7.1 upgrade
From config tool, I am not able to find upgrade from 5.0 to 7.1 option, we have 7815I2 server, please light me we cannot upgrade 7815 5.1 to 7.1 CUCM version
Community Member
Re: Configurator Tool I am not able to find CUCM 7.1 upgrade
Hello
For upgrades to CUCM 7.1 you do not have a upgrade item, you have to purchase an new CUCM installation, according to ordering guide:
Cisco Unified CallManager 4.x or Cisco Unified Communications Manager 5.1 to Cisco
Unified Communications Manager7. 0
There is no migration SKU. Re-purchase Cisco Unified Communications Manager 7.0 as if
it were a new system.
Álvaro
Community Member
I have one doubt. If there isn't upgrade path how licenses of DLU's are migrated from one version to another.
For example if i have one cluster of 2 Servers with CUCM 5.1.x and i want upgrade to CUCM 7.x. if we re-purchase CUCM 7.0 as new system how DLU's are migrated?
It's enough upgrade publisher to version 7.x and install 2 server licences of CUCM 7.x? and then install subscriber.
Best Regards
MC
Community Member
Hello
It is like a minor upgrade, you download the iso a perform the upgrade, so the dlu's are the same. Then you load the node license, an you will see the the software license is the new 7.x.
Regards.
Álvaro
302
