Configurator Tool I am not able to find CUCM 7.1 upgrade
From config tool, I am not able to find upgrade from 5.0 to 7.1 option, we have 7815I2 server, please light me we cannot upgrade 7815 5.1 to 7.1 CUCM version
James Hawkins
Level 8
Level 8
Your server is capable of running CUCM 7.1 but may need a memory upgrade - its needs 2GB RAM and a 72/80GB hard disk - see link below:
https://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
As for the upgrade license you need to buy a new node license for your server using the part code below:
LIC-CM7.1-7816= License Unified CM 7.1 7816 Appliance, 500 seat
This costs $3995 list. You can get Cisco licensing to reisuue you 7.x compatible DLUs to the same quantity as you have on the 5.1 system.
Rob Huffman
Hi Bala,
From the ordering guide;
"Cisco Unified CallManager 4.x or Cisco Unified Communications Manager 5.1 to Cisco Unified Communications Manager7.0
There is no migration SKU. Re-purchase Cisco Unified Communications Manager 7.0 as if it were a new system.
Example 2 - Customer has Cisco Unified Communications Manager 5.1 on an IBM X3250 and wants to upgrade to 7.0. This is a supported direct path. Customer orders CM7.0-K9-X3250. If the customer also wanted a new server, use the top level SKU as in the preceding example.
Cheers!
Rob
PS: Hey James, you trumped my "monkey-man" typing skills again my friend. Nice answer here :) +5 points for this.
Hi Rob Thanks for the nice rating. +5 for you as well.
Thanks for all your reply.
Now customer is having 7815I2, I need SUB along with this, so I hope I should order only the following for the above customer: he need redundancy + upgrade
MCS-7816-I4-CCX1 - 1 nos
LIC-CM7.0-7816= - 1 nos or 2 nos required.
Again my question do i need to order two node LIC or single node LIC for the customer.
For upgrade they have valid UCSS subscription for two years.
