Configure 2811 as transcoding device
Amit Singh2000
HI Guys,
I need your help on this..I have a customer going to install CUCM solution on multiple site.. because of bandwidth limitation some sites will be running G729 over wan and some sites are running G711.... How do i configure a cisco 2811 router which has PVDM 64 installed in it as a trancoding device..
In esence i want sites running G711 and sites running G729 talk to each other and enjoy other fancy features like conference.
Thanks in advance
regards
Jaime Valencia
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
CallManager and IOS Gateway DSP Farm Configuration Example
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
java
if this helps, please rate
java
sebastiandm
Follow the attached document you should be fine.
Please rate if useful.
Hello my friend.
Thanks a lot for your reply.. I forgot to mention that we are using call manager 7.0 version..1 publisher and 3 subscriber servers...does this configuration still valid for my solution or configuration for transcoding will change ??
regards
It still works, the interface of 2nd link is just a little changed but all the IOS commands are exactly the same for any version.
java
java
