08-05-2010 01:40 PM - edited 03-16-2019 12:06 AM
I have a 2911 router that I'm trying to configure a PRI interface for but under the Serial interface I do not see the isdn commands.
Attached is my config:
IOS= c2900-universalk9-mz.SPA.151-1.T1.bin
Do I need different IOS, I looked on CCO with s'ware advisor and it tols me the version I'm using has it but can't figure out how to find them.
Thanks.
Solved! Go to Solution.
08-05-2010 02:01 PM
Your controller configuration is wrong; try a 'pri-group timeslots 1-24' instead.
08-05-2010 02:01 PM
08-05-2010 02:08 PM
Wow, how did I miss that, been a long day. Thanks for the help.
