05-15-2014 02:49 AM - edited 03-16-2019 10:48 PM
Hi, guys.
I have a CUCME environment and a couple of users on it.
I have certain dial peers already configured.
And I need to configure on certain IP Phone to use ONLY one dial peer for OUTGOING calls.
Others will still be using all dial-peers.
Can you show the commands here I have to insert on the CUCME?
Warm regards
05-15-2014 03:26 AM
Hello Edson,
you may need to configure CoR list for the ephone-DNs & for the dial-peers. Please go through these documents on how to configure it.
http://knightfoo.wordpress.com/2012/09/11/call-manager-express-class-of-restriction-cor-lists/
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
//Suresh
Please rate all the helpful answers
05-15-2014 03:27 AM
Hi, Suresh..
Let me check it. Thanks
05-22-2014 06:38 AM
if you want to restrict the usage of outgoing dial-peers then Co- list is the only option. Can you give us your running configuration with an example of your requirement.
05-22-2014 06:56 AM
Again....I want to add a third dial-peer with the same configs as dial-peer voice 2 pots EXCEPT the port....it must be port 0/0/0:15 and must be used only by...for example, the ephone-dn on the sh run below.
sh run (relevant configs)
dial-peer cor custom
name locals
name emergencies
name mobiles
name internationals
dial-peer cor list outbound-general
member locals
member emergencies
member mobiles
member internationals
dial-peer cor list outbound-except-one
member locals
member emergencies
dial-peer cor list call-emergencies
member emergencies
dial-peer cor list call-locals
member locals
dial-peer cor list call-internationals
dial-peer cor list call-mobiles
member mobiles
dial-peer voice 1 pots
corlist outgoing call-locals
description Nacionais e Locais
destination-pattern 92[13-9]......
port 0/0/0:15
forward-digits 8
corlist outgoing call-mobiles
description Moveis ou Celulares
destination-pattern 98[246].......
port 0/1/0
forward-digits 9
dial-peer voice 4 pots
corlist outgoing call-internationals
description Internacionais
destination-pattern 900T
port 0/0/0:15
prefix 00
dial-peer voice 5 pots
description Emergencia
destination-pattern 91..
port 0/0/0:15
forward-digits 8
ephone-dn 13 dual-line
number 13 secondary 21359013
label Test_Phone
description Test_Phone
name _Test_Phone
corlist incoming outbound-except-one
05-22-2014 07:30 AM
Hello Edson,
can you try the below config and let me know if it works as expected?
1) add "member isdn" under custom corlist & call-mobiles corlist
2) create the 'dial-peer voice 3 pots' like below and assign corlist call-mobiles and preference 0
preference 0
port 0/0/0:15
forward-digits 9
3) add the command "preference 1" under dial-peer 2
4) on 'ephone-dn 13' change the corlist to 'corlist incoming call-mobiles' instead of 'outbound-except-one'
please test this and let me know how it works.
//Suresh
Please rate all the helpful posts
05-22-2014 06:20 AM
Hi, Suresh....
I managed to do it.
Now I wanted to make it possible to separate the outgoing calls for SAME destination-patterns.
For a specific ephone-dn, use a different dial-peer (another port) and other ephones remaining using the same dial-peer...for the same destination-pattern.
Any help?
/EV
