07-30-2013 10:12 PM - edited 03-16-2019 06:38 PM
Hello guys,
I have configured BLF Speed Dials in CUCM v9.1 but I'm still not able to configure them from the users web access (they just don't appear in the ccmuser web access), does anyone know if it is posible in this new version???
With regular Speed dials it works perfect but with BLF nop.
Thanks in advance for your comments.
Solved! Go to Solution.
07-31-2013 05:25 AM
Hi Alfonso,
Just thought I'd add a reference to the good info from Java (+5)
From the CUCM 9.x SRND;
Unified CM supports the ability for a speed dial to have presence capabilities by means of a busy lamp field (BLF) speed dial. BLF speed dials work as both a speed dial and a presence indicator. However, only the system administrator can configure a BLF speed dial; a system user is not allowed to configure a BLF speed dial.
The administrator must configure the BLF speed dial with a target directory number that is resolvable to a directory number within the Unified CM cluster or a SIP trunk destination. BLF SIP line-side endpoints can also be configured with a SIP URI for the BLF speed dial, but SCCP line-side endpoints cannot be configured with a SIP URI for BLF speed dial. The BLF speed dial indication is a line-level indication and not a device-level indication.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/presence.html#wp1084090
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
07-30-2013 10:28 PM
No, you cannot configure BLF via CUCMUSER page
07-31-2013 07:58 AM
Thanks Jaime!
07-31-2013 05:25 AM
Hi Alfonso,
Cheers!
Rob
- Stones
07-31-2013 07:59 AM
Thanks alot Rob!!!!
Now it is clear to me.
Best Regards,
