configure Call Forward
I configured the CME on the Cisco 2800 and it works
But now I need to configure these two operations
1. When the user does not want to disturb or is out of ofice, all calls are automatically transferred to another user B (the number of User B must be configured manually, and this configuration can be deleted or changed manually by each user if needed)
2. When the user receives a call, if the phone rings 3 times and he does not answer, the call is automatically forwaded to the user B, then if the user B phone rings 3 times and he does not answer, the call is automatically forwaded to the user C, then if the user C phone rings 3 times and he does not answer, the call is automatically forwaded to the user A (the first original user when the call was intended)
Thank you for the help
I read the 2 link, but I am really confuse
Can some body help me to made the 2 configuration
Thans in advance
Green
Can you post the
show run
Also explain what number is to transfer to what other number
Is it be on No Answer
No Answer and Busy
Alex
Regards, Alex. Please rate useful posts.
Re: configure Call Forward
Thanks for your answer
CASE 1. When the user 6100 does not want to disturb or   is out of ofice, he configure on their phone that all calls are   automatically transferred to another user 6104 (the number of User B   must be configured manually, and this configuration can be deleted or   changed manually by each user if needed)
CASE   2. When the user 6100 receives a call, if the phone rings 3 times and   user 6100 does not answer, the call is automatically transfered to the   user 6127, then if the user 6127 phone rings 3 times and he does not   answer, the call is automatically transfered to the user 6117, then if   the user 6117 phone rings 3 times and he does not answer, the call is   automatically forwaded to the user 6100 (the first original user when   the call was intended)
so in CASE2,  the cal is transfered after 3 ring without answer
see the sh run attached
Green
Can you add these lines to your config :-
telelephony-service
transfer-system full-consult
transfer-pattern .T
call-forward pattern .T
!##  TO PERFORM A SIMPLE FORWARD ON NO ANSWER OR BUSY
!##  USE THIS
ephone-dn  1  dual-line
number 6100
call-forward busy 6127
call-forward noan 6127 timeout 10
huntstop channel
!##  FOR A COMPLEX FORWARD USE A HUNT GROUP
!##  PLEASE POICK YOUR OWN PILOT, IHAVE ONLY
!##  SELECTED 6199 AS AN EXAMPLE
ephone-hunt 1 sequential
pilot 6199
list 6127, 6117, 6100
final 6100
timeout 10, 10, 10
no-reg pilot
number 6100
call-forward busy 6199
call-forward noan 6199 timeout 10
huntstop channel
Alex
Hi and thanks for you answer, I will try it
Please If I need (in the case2) the call to be forwaded in the 6100 mail boxe if there is no answer what is the good configuration
CASE   2. When the user 6100 receives a call, if the phone rings 3  times and   user 6100 does not answer, the call is automatically  transfered to the   user 6127, then if the user 6127 phone rings 3 times  and he does not   answer, the call is automatically transfered to the  user 6117, then if   the user 6117 phone rings 3 times and he does not  answer, the call is   automatically forwaded to the user 6100 (the first  original user when   the call was intended),
if the phone rings 3  times and   user 6100 does not answer, the call is transfered to the 6100 voice mail
Ho can I do this configuration
Thanks in advance for your help
Green
Then change
pilot
6199
final 6100
timeout 10, 10, 10
no-reg pilot
Make the Final the vmail number
e.g.
final 6666 ( if that was the vmail number)
Alex
Hi and thanks for your answer
I tried the configuration as you ask but only calls coming from internal (local) user are transfered
1. TO PERFORM A SIMPLE FORWARD ON NO ANSWER OR BUSY
I configured manually call foward (cfwdall) on 7961 ip phone (I would like to note that this phone 6100 is installed at the hotline and receive directly all PSTN incominm call)
  - only calls coming from internal (local) user are automatically forwaded
  - Incoming calls coming from (outside) PSTN line are not forwaded
2. FOR A COMPLEX FORWARD USE A HUNT GROUP
  - only calls coming from internal (local) user are forwaded
Thanks for your help
Hello
Please I need help regarding the message below
Green
Sorry for the delay.
Can you post the full current config.
show run
Alex
I configured manually call foward (cfwdall) on7960 and 7961 ip phone  (I would like to  note that this phone 6100 is installed at the hotline and receive directly all  PSTN incominm call)
2. FOR A COMPLEX FORWARD USE A HUNT GROUP (1): 6100-6102-6111-6100     /   (2) : 6101-6102-6126-6101
Green
Can you try removing this line :-
dialplan-pattern 1 2001.. extension-length 3 extension-pattern 2..
telephony-service
no dialplan-pattern 1 2001.. extension-length 3 extension-pattern 2..
Retest
Alex
Hello
I apologize for the long silence, I was changed the router and other equipment on the network
Currently everything has been redesigned and even the router was changed, but I still have problems
See the list of issues below
1.
I can not make a call forward as you show me
I need to call the sequential forward with two lists below
list 8101, 8114, 8111, 8101
list 8100, 8114, 8111, 8100
I configured but it doesnt work
2.
The number 8100 does not receive call
When calling this number you get this message: There Is No mailbox associated with this extension
How to fixe it ?
3.
The display screen of phone number 8100 (phone 7931) does not seem normal
Here's what it displays:
03 telco
zain 02
Not assigned 01
It is impossible to make call in " hand free" on this phone, to call, you must pick up the phone or press "new call" to get the dial tone and call normally. In addition when you call, the caller phone displays this  : "zain from 281" which is not normal, it should show "from 8100". It look like he confuse the line
how to solve it, How to use automaticaly the line 8100 for internal call
4. I want that all incoming call on the two external gsm lines  (dafone zain) ring directly on the 8100 phone, now they ring on the 8101
How to change it to ring on 8100
Can you help me with these four configurations
Thank  in advance for your help
Please I need your Help.
Green
From your config
pilot 8101
ephone-hunt 2 sequential
pilot 8000
ephone-dn  2  dual-line
number 8101
You must use distinct DNs for your PILOTS
8101 can not belong to an ephone-dn and a hunt group.
Alex
Ok will try it and let you know
What about the other problem
Can you help me please
I am desapointed
Green
Again from your config
ephone-dn  80  dual-line
number 8100
label standard
name standard
call-forward busy 6000
call-forward noan 6000 timeout 10
So this is button 80
Your 7931 has no mention of button 80
ephone  2
mac-address 3302.4784.FD78
type 7931
button  2:81 3:84
May be change this to :-
ephone  2
type 7931
button  1:80 2:81 3:84
And reset phone
Also have you built a mailbox on CUE for 8100
Alex
836
