Configure CDR
Dears,
I have billing software (installed in PC) that will gather 2 CDR file from AVAYA call manaher and Cisco getway, I was able to send CDR from Avaya( easily send the file by specify PC's IP  that billing software is installed on it )    but I can't configure Cisco to be able to send CDR file to the billing software
So could anyone help me on that
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 23-Aug-11 01:31 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
VGW1 uptime is 3 weeks, 1 day, 1 hour, 25 minutes
System returned to ROM by reload at 11:35:13 UCT Sat Jun 1 2013
System image file is "flash:c2800nm-ipvoice_ivs-mz.124-24.T6.bin"
Cisco 2851 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FTX1144A29J
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
12 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
------------------ show running-config ------------------
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
Configure CDR
Wrong forum, post in "IP telephony". You can move your post using the actions panel on the right.
320
