Community Member
Configure Cisco 7945 as SIP phone
i am Trying to configure Cisco IP phone 7945 as a SIP phone but i am not able to do the same, the phone is restarting and in CCM its showin Rejected
what i have to do to solve the sam.
1 REPLY
Community Member
Re: Configure Cisco 7945 as SIP phone
Hi Muzzamil,
What version of Call Manager are you running?  This should be supported as of Version 5.
The following link explains configuring a Cisco IP handset to use SIP:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml#topic1
If you are seeing the registration rejected message on the phone, it could be that you have either not added the device to Clall Manager or you have not enble auto registration on the Call Manager cluster.
I would also have a look at this document to check the auto registraion:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080708526.shtml
If you are not configured for auto registration, you will need to manually add the device by entering it's MAC address in Call Manager.
Post back if this helps or not, and good luck!
Kind regards, Ash.
3720
