Configure cisco VG224 using MGCP protocol
Hi Team,
I would like to know, How to configure Cisco VG224 using MGCP
1.What Configuration will do on VG 224
2.What Configuration will do Call Manager 8.6
Praful S.
Everyone's tags (1)
Hall of Fame Super Gold
You should use SCCP with Vg224 on CM. Not MGCP.
Re: Configure cisco VG224 using MGCP protocol
Config is pretty much the same as for any ISR if you want MGCP on the VG224
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Super Bronze
Paolo-
It is common to configure FXS ports for MGCP control since SCCP doesn't support protocol-based T.38 switchover. This is typically required (as opposed to NSE-based switchover) in environments that have a third-party fax server.
For the original question:
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server
ccm-manager download-tones
ccm-manager config
mgcp
!Possibly related commands if the hardware will be doing faxing, esspecially T.38v0.
mgcp modem relay voip mode nse gw-controlled
mgcp package-capability fm-package
mgcp fax t38 ls_redundancy 2
mgcp fax t38 hs_redundancy 2
mgcp package-capability fxr-package
no mgcp fax t38 inhibit
Please remember to rate helpful responses and identify helpful or correct answers.
766
