Configure DND on Hunt Group
As what i know in CME, when you configure hunt group. The group member are able to Prevent/Skip the phone ringing when he press the DND button. Any similar feature on CCM 4.1 Hunt Group?
thank you
1 ACCEPTED SOLUTION
Re: Configure DND on Hunt Group
That feature isn't available until 4.2. In CM 4.2, the Hunt group member has ability to login or out of the Huntgoup much like the DND feature on CME.
1 REPLY
127
