Community Member
Configure Expansion Module 7916 on CME 7.1
We have CME version 7.1, and have connected 2 Nos 7916 to Cisco 7942G IP Phones. How do we make the expansion modules to work. Is there any specific configuration for the expansion modules?
Thanks.
Hall of Fame Super Gold
Re: Configure Expansion Module 7916 on CME 7.1
You only need the correct firmware and type configuration under ephone.
Community Member
But is the 7916 compatible with 7942?
also does Double Cisco Unified IP Phone Expansion Module require separate power supply or can the double expansion module work with the inline power from the cisco ip phone?
Not with the 7942, but with the 7962. I did not read correctly the module in your first question.
I the phone has PoE, you only need a single PS for two modules.
Please remember to rate useful posts with the scrollbox below.
1553
