Configure Fax Relay
Hi to all,
How can i configure a mgcp gateway with the FAX RELAY in a CCM 4.2(1).
Best regards,
Alberto
1 REPLY
Silver
Re: Configure Fax Relay
By default the Cisco MGCP gateways use an NSE-based switchover for T.38. The commands to configure protocol-based T.38 on the MGCP gateway are -
no mgcp fax t38 inhibit
mgcp default-package fxr-package
mgcp package-capability fxr-package
The following URL will help you:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/t38.html
270
