02-11-2014 12:11 AM - edited 03-16-2019 09:41 PM
Hello, I am Amadou Dia CCNA Voice.
I had a cisco telephony project to deploy in 3 sites (One CME 2911 and two CME 2901). I did the deployment correctly, now my problem is that i have many 6911 IP Phones in the deployment and i would like to know how to configure the button of function (pickup, meet me and others).
Can anyone help me please? it is urgent.
Cordialy,
Amadou Daouda DIA
Solved! Go to Solution.
02-11-2014 12:29 AM
You need to configure ephone-template to achive this.
Check the above link shared by Kevin.
Here is example from the doc...
enable
configure terminal
softkeys connected {[Acct] [ConfList] [Confrn] [Endcall] [Flash] [HLog] [Hold] [Join] [LiveRcd] [Park] [RmLstC] [Select] [TrnsfVM] [Trnsfer]}
softkeys hold {[Join] [Newcall] [Resume] [Select]}
softkeys idle {[Cfwdall] [ConfList] [Dnd] [Gpickup] [HLog] [Join] [Login] [Newcall] [Pickup] [Redial] [RmLstC]}
softkeys seized {[CallBack] [Cfwdall] [Endcall] [Gpickup] [HLog] [MeetMe] [Pickup] [Redial]}
exit
ephone phone-tag
end
02-11-2014 12:24 AM
Here is a link for your reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
Kindly rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
02-11-2014 12:29 AM
enable
configure terminal
exit
ephone phone-tag
end
02-11-2014 12:43 AM
Hello Kevin and Manish thanks for the answer i will test it and back to you the result. Thank you again
02-15-2014 01:27 AM
Hello Kevin and Manish i have done by using the features-button on config template mode thanks for help.
#ephone-template template-tag
#feature-button 2 Pickup
#ephone 1
02-15-2014 01:39 AM
Thank you for the update and if you question is answered , then mark it as answered and rate all the useful posts.
Manish
