Configure features button of 6911 IP Phones on CME 9
Hello, I am Amadou Dia CCNA Voice.
I  had a cisco telephony project to deploy in 3 sites (One CME 2911 and  two CME 2901). I did the deployment correctly, now my problem is that i  have many 6911 IP Phones in the deployment and  i would like to know how  to configure the button of function  (pickup, meet me and others).
Can anyone help me please? it is urgent.
Cordialy,
Amadou Daouda DIA
  • IP Telephony
1 ACCEPTED SOLUTION
You need to configure ephone-template to achive this.
Check the above link shared by Kevin.
Here is example from the doc...
enable
configure terminal
ephone-template template-tag
softkeys connected {[Acct] [ConfList] [Confrn] [Endcall] [Flash] [HLog] [Hold] [Join] [LiveRcd] [Park] [RmLstC] [Select] [TrnsfVM] [Trnsfer]}
softkeys hold {[Join] [Newcall] [Resume] [Select]}
softkeys idle {[Cfwdall] [ConfList] [Dnd] [Gpickup] [HLog] [Join] [Login] [Newcall] [Pickup] [Redial] [RmLstC]}
softkeys seized {[CallBack] [Cfwdall] [Endcall] [Gpickup] [HLog] [MeetMe] [Pickup] [Redial]}
exit
ephone phone-tag
end
Re:Configure features button of 6911 IP Phones on CME 9
Here is a link for your reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
Kindly rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
enable
configure terminal
exit
ephone phone-tag
end
Hello Kevin and Manish thanks for the answer i will test it and back to you the result. Thank you again
Hello Kevin and Manish i have done by using the features-button on config template mode thanks for help.
#ephone-template template-tag
#feature-button 2 Pickup
#ephone 1
Thank you for the update and if you question is answered , then mark it as answered and rate all the useful posts.
Manish
344
