Configure Force Authorization Code at CME
Hi All,
Do you know on how to configure FAC at CME ?
I want to put PIN code when access to particular destination number
Thx,
Suryanto
Re: Configure Force Authorization Code at CME
     You  can set pin only on Phone level not like CUCM. In CME FAC means Feature Access Code not Force Authorization code
Hi ,
Thx for the answer.
However what should be done is I want to have an International Call to be controlled by using PIN Code.
And i configure it at CME.
BR,
SURYANTO
    Please follow the below steps
under telephony service
login timeout 1
after-hours day Sun 00:01 23:59
after-hours day Mon 00:01 23:59
after-hours day Tue 00:01 23:59
after-hours day Wed 00:01 23:59
after-hours day Thu 00:01 23:59
after-hours day Fri 00:01 23:59
after-hours day Sat 00:01 23:59
after-hours block pattern 1 900    >> 9 is prefix
ephone 10
pin 12345
restart.
Now press  Login softkey button dial 12345
will be able to dial international starting 900..................
This has been asked already PLENTY of times before, the options are using the after-hours or there is a script which is not supported but does the job.
You can find info on both methods by just searching FAC + CME using the search box at the top right on the page.
Please search NetPro for answers before posting a question.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Silver
3188
