configure fractional or partial T1 PRI with MGCP and Cisco CallManager
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K14305072
I'm trying to find the step 2 settings to configure fractional or partial T1 PRI with MGCP in Cisco CallManager. It talks about copying and pasting this parameter, but where?
thanks,
Mike
Hall of Fame Super Silver
Re: configure fractional or partial T1 PRI with MGCP and Cisco C
You paste it into the "B-Channel Maintenance Status " field, you may need to click the "Advanced" setting in order to see it.
HTH,
Chris
is there way to do this on the router and for it to keep its config even if the router reboots?
we are running into where the router will reboot and CCM will push its own config down.
420
