Configure Operator Phone 7931
Dear All,
I have implemented IPTX in my office. I need to configure operator phone (7936) with buttons. Can anybody help me in this regard.
Below is the configuration of the ephone-dn and ephone of the operator.
ephone-dn 11 dual-line
number 4250
label AHMED AL KHWAJA
name AHMED AL KHWAJA
call-forward busy 4000
call-forward noan 4000 timeout 20
hold-alert 30 originator
ephone 18
device-security-mode none
mac-address 001B.D4C7.1184
username "T4250"
type 7931
button 1:11
Waiting for your response.
Malik.
Re: Configure Operator Phone 7931
Can anybody guide me in this regard or can anybody give me sample configuration of that i would have an idea.
Malik.
Hi Malik, I already replied to this question in a different post. Here it is:-
In order for 7931 to use Directories, Settings you have need to assign a specific template.
There are two button-sets for the 7931, button-set 1 and button-set 2, the later provides directory access.
See the button-set command from this CME guide:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_b1ht.html#wp1021058
After you assign the template to the ephone-dn, these additional buttons will be on the handset.
ephone-template 1
softkeys idle Newcall Redial Pickup Dnd Gpickup Cfwdall
softkeys seized Redial Endcall Cfwdall Gpickup Pickup
softkeys alerting Endcall Callback
softkeys connected Endcall Hold Trnsfer Confrn Park
softkeys ringing Answer Dnd
button-layout 7931 2
ephone 18
ephone-template 1
Also take a look at this document, it discusses changing fixed line feature buttons for the 7931:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html
Hope this helps
Allan.
Pls rate helpful posts.
206
