Community Member
Configure Router to default to answering service.
Hi All, I have a single site deployment with one 2821 gateway and one callmanager. We have an answering service that we use to take calls after hours. I've been given the task to see if I can set the router to default to the answeing service if our callmanager goes down. Is there a way I can configure this on the router? Thanks for the help
equipment info:
Cisco 2821
IOS version (C2800NM-SPSERVICESK9-M), Version 12.4(22)T
1 PRI threw timewarner
Callmanager system version 6.1.2.1002-1
Re: Configure Router to default to answering service.
If you're using H323:
translation-rule 1
rule 1 /.*/ /5551234/ <-- 5551234 is the number of your answering service
translation-profile 1
translate called 1
dial-peer voice 1 voip
destination-pattern 5... <-- for example we're saying your DNs are the 5XXX range.
preference 0 <--default
dial-peer voice 2 pots
translation-profile outgoing 1
preference 1
port 0/0/0:23
MGCP:
Well, it would look the same, except you wouldn't have dial-peer 1. You might if you're using fallback.
So it would be:
ccm fallback-mgcp
translation-rule 1
translate called 1
preference 1
port 0/0/0:23
Does this make sense?
hth,
nick
Community Member
Hi Nick I already have to two dial-peers in my gateway:
dial-peer voice 9999999 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:23
dial-peer voice 9994900 voip
description H.323 routing to CM
destination-pattern 49..
session target ipv4:192.168.103.10
do I still need to add your dial-peers or just the translation pattern?
thanks for the help,
Mike
Hi Mike,
Yes you're using H323. So you would follow the example of the first one.
You would make a secondary pots dial peer with the destination-pattern of 49.. and a preference of 1 or higher, with the translation pattern.
hth,
nick
Community Member
Hi Nick,
Here is what I inputed into the router:
voice translation-rule 1
voice translation-profile 1
translate called 1
preference 1
port 0/0/0:23
dial-peer voice 3 pots
preference 1
destination-pattern 6040
port 0/0/0:23
The translation works great I first tested it to my extension and I had it call my cell phone and it worked. However, when I enabled for all extensions "49.." and did a "shut" on the switch port for our callmanager and called our office numbers It does not go threw. If I change the prefence to zero it works however, once I enable the switchport for callmanager it still forwards to translation number and does not revert to sending calls to our callmanager?
What am I missing?
thanks for your help,
Mike
Hi Mike,
I think your voip dial peer isn't going into the down state when CCM isn't reachable.
You can add this to your CCM voip dial peer so that it pings CCM to maintain that the dial peer is still valid:
nicmatth-sip(config-dial-peer)#monitor probe icmp-ping 1.1.1.1
Keep the preferences like I had mentioned, just add this to your voip dial peer.
'show dial-peer voice summary' should show the "Out Status" of the dial peer as up/down, depending on the reachability.
hth,
nick
Community Member
Hi Nick, thanks for the help thus far. I did as you reccommended however, when I dial in I still get a fast busy. If I do a "sh vo call sum" I see the call comming into the router:
But then it looks like it gets dropped, here is part of my config starting with my voice port maybe you can see something that I'm missing:
voice-port 0/0/0:23
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.103.10
ccm-manager config
mgcp
mgcp call-agent 192.168.103.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
direct-inward-dial
port 0/0/0:23
monitor probe icmp-ping 192.168.103.10
dial-peer voice 9994988 voip
description SIP Fax for 4988
answer-address 5205551234
destination-pattern 4988
session protocol sipv2
session target ipv4:192.168.100.16
session transport udp
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback pass-through g711ulaw
clid network-number 5205551234
no vad
dial-peer voice 9990911 pots
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 9999911 pots
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 9996040 voip
dial-peer voice 9994984 voip
description SIP Fax for 4984
answer-address 5205554321
destination-pattern 4984
session target ipv4:192.168.100.17
codec g711ulaw
fax rate 14400
clid network-number 5205554321
no vad
preference 1
port 0/0/0:23
preference 1
port 0/0/0:23
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.103.1 port 2000
max-ephones 52
max-dn 192
system message primary Phone System in local mode
default-destination 4985
thanks for you help,
Mike
Hi Mike,
What we're really interested in is whether the 'show dial-peer voice summary' shows that dial-peer 9994900 has a 'down' 'Out Status' when you shut the port. It may take a while for the monitor to take effect.
Other than that, dial peers seem to be in order.
-nick
Community Member
Hi Nick, thanks for helping me out thus far. I did some more testing tonight and after I shut down the switchport for out callmanager and issue the show dial peer voice summary this is the output it shows me:
Core-2821#sh dial-peer vo sum
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
99999- pots up up 9T 0 up 0/0/0:23
99
99949- voip up up 49.. 0 syst ipv4:192.168.103.10
00
99949- voip up up 4988 0 syst ipv4:192.168.100.16
88
99909- pots up up 911 0 up 0/0/0:23
11
99999- pots up up 9911 0 up 0/0/0:23
11
99960- voip up up 6040 0 syst ipv4:192.168.103.10
40
99949- voip up up 4984 0 syst ipv4:192.168.100.17
84
20001 pots up up 4988$ 0 50/0/1
20002 pots up down 0 50/0/2
I kept the switchport down for about 12-15 minutes and I could never get the router to forward the call to my cell phone.
Any other suggestions?
thanks,
Mike
Community Member
Hi, Im attaching a text file with the output command thats a little more readable.
thanks,
Mike
264
