Configure SIP TRUNK on CISCO 2851
Hi I have configured SIP trunk from service provider for the incoming calls so that it lands on to our VXML application . When I am calling , there are no SIP events generated . I am able to ping the SIP server of service provider . Plz help
Configuration is as below
Building configuration...
Current configuration : 2098 bytes
! Last configuration change at 11:36:37 UTC Thu Jul 10 2014
version 15.1
hostname Router
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M3.bin
boot-end-marker
no aaa new-model
no network-clock-participate wic 0
no network-clock-participate wic 1
no network-clock-participate wic 2
no network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice call carrier capacity active
voice rtp send-recv
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to sip
 redirect ip2ip
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice class codec 1
 codec preference 2 g711ulaw
voice-card 0
application
 service first http://203.122.28.180/try.vxml
license udi pid CISCO2851 sn FHK1009F1NQ
redundancy
controller E1 0/0/0
controller E1 0/1/0
controller E1 0/2/0
controller E1 0/3/0
 ip address 10.50.129.82 255.255.255.252
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 203.122.28.181 255.255.255.248
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 10.0.0.0 255.0.0.0 10.50.129.81
ip route 203.0.0.0 255.0.0.0 203.122.28.177
control-plane
mgcp profile default
dial-peer voice 3000 voip
 service first
 session protocol sipv2
 session target ipv4:10.50.129.50
 incoming called-number .
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
sip-ua
 authentication username 6671111 password 7 101F5B4A51
 registrar ipv4:10.50.129.50 expires 3600
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
1 REPLY
 Dear live, First you should
Dear live,
First you should need the connectivity ,then only you can create sip trunk
When you ping to service provider,what is the reply getting ?
Ajay Jose k
307
