configure toll fraude prevention c880voice
Hello: I need to configure toll fraude prevention in three of my routers, Ios versions:
c880voice-universalk9-mz.124-24.T6.bin
c880voice-universalk9-mz.150-1.M8.bin
I used the following guide, which according to Cisco, is intended for ios version 12.1 or later:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/107626-cme-toll-fraud.html
This is the configuration I planned to use, but my routers do not support any of the commands under "voice service voip",
Router> enable
Router# configure terminal
Router(config)# voice service voip
Router(conf-voi-serv)# ip address trusted authenticate
Router(conf-voi-serv)#ip address trusted call-block cause call-reject
Router(conf-voi-serv)# ip address trusted list
Router(cfg-iptrust-list)#ipv4 10.0.0.0 255.0.0.0
Router(cfg-iptrust-list)#end
I have been seaching for equivalent commands but haven't found any.
Is there anyone with experience configuring toll fraud prevention for devices with IOS release older than 15.1(2). What am I doing wrong?
Thanks in advance!
VIP Super Bronze
This feature did not exist
This feature did not exist pre 15.1(2). If you need it I suggest you upgrade your IOS. There is no concept of toll fraud prevention in older IOS releases
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
As Ayodeji suggested, it is
As Ayodeji suggested, it is recommended to upgrade the IOS for this feature.
Or esle, you can try configuring Access-Lists to block the traffic coming from un-wanted IPs
40
