Configuring 7920
d.bigerstaff
Just a quick question...
Is there a way to configure this phone without using a USB cable and the Configuration Utility?
I've got them on order now but was hoping there was a way to get this 7920 working before they get here.
Thanks for your help.
icabrera
Level 4
Level 4
Yes, I always configure it using the key pad without no problem.
With the phone you'll probably have a user guide that explain how to do it or you can see the next url too:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a008047fa3f.html
Hope this helps you, if so pls rate the post
Regards.
icabrera
Level 4
Level 4
Regards.
Thanks for the help, i've got it working for now.
