05-29-2008 11:12 AM - edited 03-15-2019 10:57 AM
Hello All...
I'm trying to put together a line group for each one of our call centers as a backup plan in case IPCC fails. My question, can I use the 5-digit extensions that the call centers use when their agents are logged into IPCC? I know in the administration screen it states "do not include directory numbers of application controlled IP phones, or application monitored IP phones in the line group."
I just want to make sure before I jump into this, because if I can't add those extensions, then I have to create 100+ new ones for those agents.
Thanks everyone.
Solved! Go to Solution.
05-29-2008 11:19 AM
I belive officially it is not supported, however I have done it several times without an issue.
Chris
05-29-2008 11:19 AM
Chris
05-30-2008 12:54 PM
Thank Chris for your reply...
Another question: can I also configure a Hunt Pilot as "inactive?" Again, this for a backup option.
