Configuring a Local Route Group
Hi All
I was configuring Local Route Group in CCM 7.x i am a little confused
1) I have created the Route list for each site now in Route List should i add both the Standard Local Route Group AND the Route Group for that site or only the Standard Local Route Group
2) In the Route Pattern On the RouteList/Gateway Field I dont see any Local Route Group Definition So how do i define which RL to use since Both sites uses the Same Route pattern. So what do i configure for this field
In the device pool for each device pool i have already mentioned the Local Route there
Please do Help
  • IP Telephony
Re: Configuring a Local Route Group
You no longer require a Route List per site. One Route List which selects the local route group can be used for all sites on the cluster and the calls will go out of the local gateway.
thank you
one more query so in the route list i just have to mention standard local route group and create route patterns with that route list correct ?
how do we configue Tail end hop off using local route groups ?
540
