07-16-2009 02:05 PM - edited 03-15-2019 06:59 PM
Hi Dear All,
I just would like to know how configure a MTP on a 3845 router (registered as MGCP at the CUCM) and I associate on the CUCM 4.1.3
Please send me some examples.
Andres
Solved! Go to Solution.
07-16-2009 06:30 PM
Enhanced Transcoding and Conferencing for IOS Voice Gateways in a CallMananger Network using DSP Resources Configuration Example
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
java
if this helps, please rate
07-16-2009 06:30 PM
java
